Re: Project 81 Monte Build LQ9 Powered-Painted!
After seeing what RELL88SS did to correct the problem with the angle the driver side collector is on the pacesetter f-body headers I thought id give it a try on my own. I actually ended up doing it a bit different and am really happy with the results. I measured where the collector needed to be then cut the collector off on an angle. I then rotated the piece I cut off 180 deg which not only straightens the collector but also puts the O2 sensor hole on the outside which gives more clearance for guys running efi. Did take some minor trimming to get it perfect but was pretty simple overall. Once I had it where I liked it I welded it on. Both ways work fine just a different take on how to straighten the collector so your exhaust has a straighter run at the header.
The engine is on a bit of a lean so it may look a bit weird but the collector is straight trust me
