I have the Holley motor mounts. They hit the AC compressor and the bolt holes aren't even close. This pic shows the passenger side mounted backwards. Anyone else have this issue with a 6.0? View attachment 142190
I have the Holley motor mounts. They hit the power steering pump and the bolt holes aren't even close. This pic shows the passenger side mounted backwards. Anyone else have this issue with a 6.0? View attachment 142190
The instructions are clear. The motor frame mounts are correct. The motor mounts aren't clearing my AC compressor. This is what it looks like in the correct orientation. The bolts are in the top motor mount holes.You need to use the forward mounts on the frame. Holley mounts fit perfect if installed correctly.
The instructions are clear. The motor frame mounts are correct. The motor mounts aren't clearing my AC compressor. This is what it looks like in the correct orientation. The bolts are in the top motor mount holes. View attachment 142201 View attachment 142202
they're not supposed to.The motor mounts aren't clearing my AC compressor.
