LS2 4l65e dead.. rebuilt or go 4l80e?
7,989
18,702
When you compare the diameter of the output shaft of the 60/65/70E to that of the 80/85E, you realize how much more stout the 80E/85E is. I'll leave the 60E in my 260 horse Roadmaster but that's it for me.
If the OP is interested, there is a link to the thread on my truck and I cover the swap in it, including the minor wiring (re-pinning) and other modifications.
8,827
7,781
No surprise the 4L65E failed, probably the very common no 3rd or 4th gear, just not enough clutches to live, especially towing.
Patobusta
19
First, thanks for all the comments and suggestions..
It seems 4l80e es us the way to go.. I wont say i wont miss the 1 and overdrive of the 4l65e, but being able to actually hammer the car a bit with no remorse will be great.
However.. and important point i have not considered was arised, wiring. I bought my psi swap harness specifically for the gto ls2/4l65e, and till now assumed any other "e" transmission will just work.
Would it be just changing a few conextors and hptuners tune or actually major changes are required?
7,989
18,702
You just have to re-pin the main connector and have the tune segment swapped. Check out my thread in my sig.
Injectedcutty
G body LS mafia
Nov 24, 2014
6,057
22,811
Louisville, KY
Jared should be able to comment since his swap was similar. The tune does have to be changed in HP Tuners, and a segment swap has to be performed(easy).
I have a cam/headers/exhaust 5.3 and junkyard 80E in my Cutlass and it's a blast! The cam is. 613/.590 lift on a 215/219 duration and 113lsa. I did put a shift kit in it, and also invested in a billet custom spec'd converter from FTI and it really does make a difference! You'd never know the car had that heavy trans in it, especially with the 3:73's out back.
HTH,
Scott
Patobusta
19
Given i have a stock cam, and not planing to change it in the near future..
Will a stock 80e converter still work? Or u definitely need to upgrade it?
7,989
18,702
A stock converter will work but a custom converter is well worth the spend and will not disappoint. The stock converter is a truck piece and is very tight
