Making a custom instrument cluster
dingo84 said:
I want to swap out my original instruments with all Auto Meter ultra-lite electric gauges.
I've seen pictures of home made clusters to fit these, but does anyone have a template with measures etc?
Also there's a complete cluster on gbodyparts but it has not yet been launched for sale.
Anyway, will be fun to make my own. Just wonder what warninglights and such I should include on this custom cluster.
Turnsignals offcourse.. And hi-beam, brake circuit-failure... What else? I have scrapped the ECU since I got carb engine. Just need the most common and important warninglights, and need to know which cables from the original harness goes to what instrument-light. Should I put on resistors or directly to the led?
What kind of car do you have? I created a template for my regal for 2 1/16 gauges and 3 3/8 speedo and tach....the original I did in a freeware 2D CAD program (now I have AutoCad) and had buddy (who runs a machine shop) cut it out of aluminum...one thing I didn't think about was the warning lights, so I'm thinking of creating a version 2.0, if you will with 1 less gauge and spots for warning lights/high beam/turn signals (just finished school Tuesday, so I plan on working on it over the holidays)...but I can PM you the template as a PDF of the drawing if you want.....I've been meaning to create a thread about it but haven't had time.
wonderboy24 said:
hey jking78 . they are made by COMP II i thought they were Marshall gauges lol but thats where they were made. . the speed o is digital. i dont really care for the plane jane set. i got them from a guy on ebay.i think i paid right around 300.00 for the set. he has a video in the listing that shows them when they light up. they are pretty kick *ss. here is the link.
http://www.ebay.com/itm/6-Gauge-Set-Ele ... 417a6&vxp=
here's the video http://www.youtube.com/watch?v=nJwOOL9XlA8
Thx nice gauged
Sent from my SCH-I545 using Tapatalk
Longroof79 said:
Thanks Jim.
Yeah, I think Ebay might be the answer. It was between that or engine turned. I think carbon fiber might rule out. :wink:
I have a quick question. It might sound a little retarded, but on the GP dash using the factory tach, where does the tach get connected?
I know one end is off the distributor, but I'm not sure about the other end of the tach filter. I removed that out of the car with the dash, but can't remember for the life of me.. 😳
JAck, the factory tack if I remember right, was just 12V, ground, signal.
The tach filter coming off of the dizzy, was a brown wire to the cap (filter), then through the firewall. There was then a connection changing the wire color to white, white went right to the tack. Depending on the dash the pin location was a bit different.
So, it is one wire from the dizzy to the tack, with the capacitor (filter) in series.
Really digging the back lite gauges. Anyone wanna buy some phantoms? lol
The only indicators I included on mine where the turnsignals, high beam and a brake light. If you really wanted to you could add a warning light for the oil pressure or water temp but that's extra wiring and sensors (depending on what gauges you go with).
You can also check out http://www.classicinstruments.com that have a few gauge lines that have the turn signals and high beam indicator's built into the gauge itself.
For the indicators I like using the ones at http://www.delcity.net
http://www.delcity.net/store/LED-Indica ... s/p_800791
http://www.delcity.net/images/photos/73386_primary.jpg
I don't have any pictures of the cluster with the above indicator's in it but here is an older pic with a different brand that looks similar. What I liked about the Delcity indicator's is that they actually had them in blue so that I could use that for the high beams:
They are the ones in the picture I posted a few posts ago. I very well may covert to the back lit gages.
liquidh8 said:
Longroof79 said:
Thanks Jim.
Jim,
I can't see where the lead would connect to the back of the tach. I have the tach filter(capacitor) with the connectors. You're right, one half of the lead is brown, the other white. I'll see if I can take a pic of the back of the tach.
Thanks man!
I'll send you a PM with a few pics.
*I apologize for highjacking this thread. Alot of cool aftermarket gauge setups.
I saw a picture of the GNX setup and thought, hell, i can do that.....
I cut the idiot light box off of a broken 81 regal gauge setup, trimmed off a box and used the factory lens from it.
