Hi, I have been down that road in the beginning. There needs to be a sleeve approximately 1/4 between the mustang 8.8 spherical bushing and the 8.8 crown vic upper ear housing. I have the exact measurements somewhere. I have not searched for crown vic specific bushings as I planned to have a sleeve installed and then the spherical bushing screwed on. I talked with a few people about this and they all said it would not be an issue especially since the spherical bushings get bolted on and not pressed in.
I have a source for sleeves. I'll post the source once I have it in my hand. But my plan is to get a sleeve and machine it to a tight fit in the housing ears and then tack weld it with nickle rod to retain them. Sleeve could be done to step it down to the 64-88 A/G body sized bushing OD or the 79-04 Ford Fox/SN sizes. I think I'm going to stick with the A/G body size.
Another detail to be attended to is the bolt size where the lower control arm mounts to the axle brackets.
The Crown Vic uses 14mm bolts. Stock 78-88 A/G body bolts are 12mm.
I am going to make some shoulder washers to step the holes down to the 12mm size.
