mounting body to frame
MrRabbit24
137
16
Tulsa
What's the bolts sizes for the body to frame ? And thread please.
pontiacgp
blank
Mar 31, 2006
29,270
20,413
Kitchener, Ontario
Position 1 uses GM P/N 10049638 (sold ea., 2 needed). Bolt is 12 X 1.75 X 95mm long.
95mm is not common so you have to use 100mm.
Position 3 uses GM P/N 14085301 (sold by pkgs. of 5, 2 needed). Bolt is 10 X 1.5 X 55mm long. Also need two nuts.
Position 2, 4, 6, 7 uses GM P/N 3524497 (sold by pkgs. of 5, 8 needed). Bolts are 10 X 1.5 X 80mm long.
MrRabbit24
137
16
Tulsa
Do you have a picture or diagram you are going off of and where can I get them I tried eBay but the ahole never sent them and never arrived it's been 2 weeks
pontiacgp
blank
Mar 31, 2006
29,270
20,413
Kitchener, Ontario
MrRabbit24
137
16
Tulsa
Thanks now do I need to buy nuts for them ? I have polythane bushings so I don't need the corroded metal things right ? Any pics would help thanks.
Carlola
344
16
Bushing kits should come with new sleeves and washers, you will need the nuts if you are buying loose bolts. If you buy a set, ie Gbodyparts, they should come with them. Prob cheaper and easier to buy the hardware local rather than order it.
pontiacgp
blank
Mar 31, 2006
29,270
20,413
Kitchener, Ontario
if you use the search tool you can find a bunch of threads dealing with body mount bolts...
MrRabbit24
137
16
Tulsa
Yea well I order the boltsfrom Gbody.com box arrived today with no bolts in it just the box and receipt I I paid extra for 2 day shipping and I get a empty Fkn box!!
