Having the day off work, yesterday I decided to go to the local Pick N Pull. My top priority was to find and remove the steering gear box (along with the pitman arm and steering shaft) from a ZJ Grand Cherokee. Being Utah, the yard was full of ZJs. I literally had more than a dozen potential candidates, which meant I could be choosy... so I decided to check mechanical odometers and select the one that was the lowest (assuming the corresponding gearbox showed no signs of leakage).
Being highly organized, Pick N Pull puts all their compact/mid-size SUVs in the same section. This meant I could also keep an eye out for 99-05 Blazers at the same time. However, this is Utah... meaning a 2WD Blazer is about as rare as hen's teeth. So you'll understand my surprise when I saw they had one 2WD vehicle, a 1999 GMC Jimmy. But wait--it gets better. As I took a closer look, I saw that someone else had already beat me to this prized gem... but apparently all they wanted were the front coil springs. When I looked at the front wheelwells, this is what I saw:
That's right, each knuckle was hanging there, attached only via the upper ball joint. All I had to do was cut the ABS sensor wire, remove the castle nut, and hit it with my hammer. Plop! The entire assembly then fell harmlessly onto the conveniently-located carpet placed there by whoever yanked the coils. In one fell swoop, I got my knuckles, hubs, calipers, caliper brackets, dust shields, all the bolts and nuts, and even a set of okay pads. I could not believe my good fortune.
The only downside was I didn't have enough money on hand for these items and a steering box... but, who cares. It's not like I won't be able to find a steering box on my next trip here.
