My 1988 Cutlass resto project
She made her maidan drive to work yesterday and today… amazed on how she drives and handles
I appreciate the kind comment, I have really enjoyed being able to start driving her. I am ringing out some minor bugs but over all very pleased with how it has come along. I am just amazed that the trunk popper, all interior lights work and even the under hood and trunk lights work!!!! The ride is smooth and firm at same time.
I have put 400 miles on her way over the past few weeks. I have this lean to the passenger side I can’t figure out. I have changed all the body bushings, swapped all the suspension from drivers to passenger side and the front has gotten within 1/4” of each other but rear is about 1” off of each other! Anyone have any ideas?
Loosen upper and lower control arms at both the differential and frame. If you have sway bar, that too. Make sure the spring upper rubber cushion (if you have them) fully seated and the spring is seated on it. Sitting on-the-ground (suspension loaded), re-tighten everything. See the RED cushion. Hope this helps.
I have done all of that except the rear sway bar. I have the factory isolators, thinking about going with the energy suspension poly for ones. Forgot to mention I have umi lower control arms and adjustable uppers. I haven’t loosed up the shock tower brace either. Guess those tow will be my next
Reactions: Tony1968
I have the same setup (UMI) you are using. The Upper frame brace doesn't do anything except horizontal bracing. IMO, I took out all my poly bushings, hate the noise and they were beginning to dry rot. Went with all rubber bushings (front/rear) by MOOG.
She looks pretty mean with those big meats hanging out in the back
