thank you and thanks everyone appreciate all the love, support, tips and help....Great build! Following
it got warm out in NJ today so I was able to pull the steering wheel change the wiper/turn signal stalk, the signal switch in the column as well...
need new flashers for fuse panel and ill be all set with that...
test fit the vacuum pump, going to be mounted where the battery is on the passenger side but on the driver side of the car (if that makes sense)
new alternator this week, going to test for draw and see what else is possibly causing a draw on the battery.
decided i am going to put a kill switch for the fuel pump so that I can keep key on engine off to diagnosis and work on electrical items witout the fuel pump running non stop
