A lot of items Jegs sells are drop shipped from the manufacturer so if that is the case they will typically take longer than an in stock item.Not yet. From what i can tell Jegs hasn't shipped them yet. I'm going to have to give them a call tonight.
If everything ever fit on the first try would this still be a fun hobby?
Any time I install a non stock part I expect some level of modification or fabrication and sometimes you have to think outside of the box to find something that can be made to work, many times I have walked around my local Lowes trying to find something I can modify to work for an application it was never designed for.Worst case would be punt the radiator for what I paid & go copper.
I have gotten the Prothane pad cushions fitted & working, just not looking forward to cutting or trimming the shroud edges on a good piece but in the name of hot rodding it'll be something I might just have to put on a pair of big boy pants & cut.Any time I install a non stock part I expect some level of modification or fabrication and sometimes you have to think outside of the box to find something that can be made to work, many times I have walked around my local Lowes trying to find something I can modify to work for an application it was never designed for.
Find out the clearance you need to fill and make it fit and use something other than factory style saddles to make it work. IMO
