I'm running a 25.7in tall tire. My local jegs has all of the speedometer gears in stock. I did do the math and thank you for verifying that I did it correctly. Using the chart and confirming with a tci rep also they recommended an 8 tooth and a 23 tooth speedo set just like you did. I know for a fact in my tailhousing I have a purple gear which is a 10 tooth and won't get me close at all to where I need to be. About $42 for all the gears and a new clip. Regardless I'm going to need new gears because they won't work with my application.I see you already did the math, so to speak. From my chart, it appears that you need 8-tooth drive gear and a 23-tooth driven gear. ..whichever comes closest to the 2.93 number.
The chart indicates a 23 tooth gear for a 2.88 ratio. and a 24-tooth gear for a 3.00 ratio.
Unfortunately. there's no in between. I'd start with the 23-tooth gear...and of course the 8-tooth drive gear. If someone has the gears cheap enough, buy the 24 tooth as well. They're relatively easy to change out.
RockAuto might be a good choice to buy speedo gears. That's the last place I bought a new driven gear.
While I am redoing my speedo gears and have to pull the tailshaft housing off I'm going to replace what I can. What all do I need a tailshaft housing gasket and a new seal is that all?
My cable is brand new also so we should be good there.
