So i need to order this hose here, is it the only hose that i need for the rears?the rear flex line that has the spliter, if you order the rear flex line that piece in installed with the line
https://www.amazon.com/dp/B000C9I3GM/?tag=gbody-20
Ok so for the rears this is my "rebuild" kit :brake line flare tool with 1/4 and 3/16 adapters, 3/16 line nuts, 1/4 brake nuts, center rear flex hose, 1/4 line, and 3/16 line. i think thats all i need for the lines right? and for the rear drums, ill just wait to order the springs and shoes because it might be a week or so.yes that is the rear flex line you need....and then of course you'll need the metal brake lines
oh i already welded the back of that fitting, i believe its just called 9/16 (for the wrench that fits on) and 1/4 tubeyes that is the rear flex line you need....and then of course you'll need the metal brake lines. If you are replacing the whole line make sure you do not lose the fitting that goes into the proportioning valve. It's for the 1/4" line and I don't know where to buy that fitting.
So the car has no brakes now?
