Correct, the clips that make contact with the gauge pod are the same clips which hold the printed circuit onto the gauge housing. It is possible but since you've stated you've pushed the center pod and no change, it seems there is something else causing the problem.
Several years ago, I installed a towing brake light circuit on my S-10 which required disconnecting and reinstalling a ground. Well, lo and behold, I experienced weird electrical problems with turn signals, lights, and gauges. When strange things like this happen, especially with automotive electrical circuits, I always go back to the last thing I touched. So, I retraced my steps and disconnected everything I installed while making sure that items like grounding straps and bolts were clean and made good contact.
From what you describe and what others have stated, it could be a grounding issue. Your statement that some items work and others don't does not mean that one of the many grounds on our elkys isn't at fault. One way to check is to find and locate all grounds and move upstream of that specific ground and do a continuity checks to validate that it is indeed making good contact.
Yes, very tedious but that is what spark chasing is all about...either you can do it or send it to a shop and pay that guy to do the simple task. Good luck!
