New found traction issues of having a stick
39F
374
Pittsburgh PA
So I was doing some testing on Sunday ,tuning carb ,checking plugs running 100 shot and 150 shot of nitrous , so I tried leaving at 4700,4500 ,4000, 3500 and 3000 car does alot of spinning not much at 3000 tho ...... My question is should I start playing with rear trailing arm angles? Spring change, shock adjustment? Car has super T10 ,427 very mild , 9 in rear with adjustable lower mounts ,QA1 adjustable upper trailing arms, adjustable lower trailing arms, 13" tall 125 lb springs, QA1 adjustable shocks ....the front has iroc front coils, tubular upper A arms, adjustable shocks, no front sway bar. Tires are 28/10/15 M/T slicks and I use 27/10/15 American racer oval slicks . I've done alot of searching and seems like I got the parts but still missing something could use some veteran advise
Reactions: fleming442
maxi426
47
I was also thinking this. Pretty hard to do meaningful chassis tuning on the street, but a stiff front end won't help things
Reactions: 39F
lilbowtie
3,307
Canton Mi
Tuning 4 Link Rear Suspensions for the Drag Strip
Tuning 4 link rear suspensions can make a car launch quicker and use less horsepower to do it. Which makes you faster, so you win, get famous, and live happy ever after...
So, let's get into it and find out how to do it...
Note: You need at least 45% of the car's weight on the rear wheels to make a 4 link suspension work properly.
Also, get some graph paper. It helps to draw out what we are doing here so you can measure and be able to set up your 4 link the easy way. You don't have to be an artist, just measure your car, height and length of the 4 links, etc. and transfer them to the paper.
Ok, first we need to know what an 'Instant Center' is.
Imagine a line going through the lower control arm extending towards the front of the car. Now imagine a line going through the upper control arm extending until it intersects the lower line. Where this intersects is called the 'Instant Center'.
instantcenter
Where the 'Instant Center' is located in the car compared to the 'Center of Gravity' of the car is what determines how the suspension acts on the car to launch it.
What you're shooting for is a position that will apply just enough force to the tires to make them grab without spinning and the rest of the force will launch the car.
Next we will figure out where to place the 'Instant Center'.
But first we have to locate our '100% Anti-Squat Line'.
Huh?
Theoretically, if the 'Instant Center' falls on the '100% Anti-Squat Line', the rear of the car will neither lift or squat, it will just be pushed foward. That's a good thing...
So let's find it... Imagine a point on the center of the rear tire contact patch. Now imagine a point on the center of the front tire contact patch.
Now take a line straight up from the front contact patch, and have it intersect the height of the center of gravity.
Note: If you need to know the center of gravity of your car, click here: How to find your Center of Gravity
Ok, now imagine a line from that point to the rear tire contact patch. This is your '100% Anti-Squat Line'.
antisquatline
Now then, let's figure out what all this means...
If your 'Instant Center' falls on your '100% Anti-Squat Line', then think of your car having as having a 'neutral' setting. The rear of the car shouldn't lift or squat, and all the horsepower should launch the car.
neutral
Now that's in a perfect world... There are lots of variables that affect that, so your car may want a little above the line, or a little below. This is where testing comes in. We'll get to that in a minute.
Now if your 'Instant Center' falls BELOW your '100% Anti-Squat Line', you will have less than 100% Anti-Squat. The rear of your car will squat and the suspension will 'lift' lightening the rear wheels. There won't be enough force applied to the rear tires and the tires will spin.
rearsquat
Now if your 'Instant Center' falls ABOVE your '100% Anti-Squat Line', you will have more than 100% Anti-Squat. The rear of the car will lift and the rear tires will be forced down, sometimes violently if it's too much. This does give more traction, but it's wasting horsepower doing it...
Sometimes high horsepower cars that have too much 'Anti-Squat' will force the tires down very hard for the first several feet but then start to unload the tires and spin when the chassis starts to settle.
rearantisquat
Now that we know how it works, let's set it up!
The way most people go about tuning 4 link suspensions is to get it in the general position they figured out on paper. Now experiment by launching the car and having someone watch or videotape it. Watch what the rear of the car and the tires do.
Now you can see what happens and adjust from there...
You're shooting for the tires to hook up without slipping, and for the car to launch foward without it lifting or squatting.
If the rear of the car squats, you want to raise the 'Instant Center'.
If the rear of the car lifts, you want to lower the 'Instant Center'.
Note: A fully-adjustable 4 link suspension allows you to move the 'Instant Center' not only up or down, but also forward or back by increasing or decreasing the angle between the bars.
If your car wheel stands too much, you can angle the 4 link bars closer together at the front to move the 'Instant Center' closer to the rear of the car.
If your rear tires are being forced down too violently you can angle the 4 link bars farther apart at the front to move the 'Instant Center' closer to the front of the car.
Now let's talk about 'Pre-Load'.
You know when you're at the track and see a car launch and it tries to pull the left front wheel up? What you can't see is it's also pulling the right rear tire up, causing it to lose traction. It's more common on large vehicles with lots of horsepower.
What's happening is the torque from the engine and driveshaft is trying to move the car, and the car is twisting around it. It's actually much more technical, but you get the idea...
You don't want this to happen.
That's when you want to use some 'Pre-Load'. If your 4 link bars are adjustable for length, you can do it there.
The first thing you want to do is make sure the upper bars are the same length and that the lower bars are the same length. This is critical.
After you get the bars the same length you need to put them back in and get the car square front to back and corner to corner.
Now the right upper bar sets any type of preload you want. It is the only bar that you adjust! Leave the other three alone.
'Pre-Load' helps offset the torque from the engine. You will usually shorten the top right bar.
Shortening the upper right bar adds weight to the right rear tire. A little does a lot. Try one 'flat' (on the adustment nut) at a time and keep track of how much you adjusted and the results. One-quarter turn can add as much as 50 pounds.
If you want to check your 4 link setup, go to a chassis shop or find someone with portable race scales. Have them put the car on the scales weigh the car with the 4 link disconnected. Then connect the 4 link, preload it and weigh again. Then you will be able to tell if each side is preloaded the same. Alot of tuning can be done this way.
Good luck!
Tuffregal83
515
Lockport, Il
My regal has has a Moroso trick spring on the left side with a competition engineering 3-way adjustable shock
And lowering springs at the other corners of the car other than that stock suspension. I'm running a BBC 468 th400 8.5 10bolt w/ 3.73 gear. It hazes the tires on the street but if I do I burnout and back into it the burnout car hooks.
Reactions: 39F and fleming442
pontiacgp
blank
Mar 31, 2006
29,412
Kitchener, Ontario
Scale your car first I see you’re from Pennsylvania most of the tracks will be open by next weekend you’re fine better results with real test track data not a cold salt covered side street
I didn't realize race tracks are considered an essential business.... :unsure:
Reactions: 39F
39F
Thread starter
Sep 9, 2019
374
Pittsburgh PA
My car has 430 gears ,I tried 1st gear burn out,2nd gear burn out helped but still not grabbing
39F
Thread starter
Sep 9, 2019
374
Pittsburgh PA
Car is 47.8 % rear weight ,51.2 right side weight ,total weight is 3532 me ,bottle and tank filled, car is a hog and I own scales,and the street is cleaned not salt or dirt or nothing around it's a old access road for a mill on it were I'm running it at
