New Here
8,239
17,742
Here's my window sticker. Can't seem to find a SPID pic at the moment. I do have one, just can't locate it.
8,239
17,742
I've always found it odd that air shocks were included with the 442, but it's not listed anywhere on the SPID or Window sticker. ANYWHERE. The build sheet has it as G3 and G4 codes, and those are codes listed on the OEM air shocks, but that's the only place I've found anything in concrete. It's possible it could be the GMD RPO but I doubt it. G66 was the RPO already for air shocks.
8,239
17,742
If my math is right, your car tallied up to MSRP of $15,550.00 when new. $10,985 base price, $4,151 in options, $414 shipping charge.
Mine only had $637 worth of extra options I didn't see on your car. The UU6 equalizer radio upgrade at $454 ($110 more than the UM6 at $344) body side moldings, $55, illuminated passenger mirror, $51, remote driver AND passenger mirror, $30, limited-slip, $100, HD battery, $26, 6-way power driver seat, $225, and Power trunk lock, $40.
The only other two options I left off of mine was the K05 block heater (I think it was around $15 or so) and the U46 external Lamp Monitor System. Forget the price of that one but IIRC, it was somewhere less than $200. So a maxed out T-top 442 would very likely cost roughly $16,400.00 in '85.
7ball
5
10
ARL- Arlington build plant code
AR9- Reclining buckets, (standard on Salon)
AU3- Door locks, power
A01- Windows, tinted
A31- Windows, power side
BD2- Cutlass Salon ornamentation- Delete (Included w/W42) *Note* This deleted the trunk lock and edge trim, door rockets, and sail panel "Cutlass Salon" emblems.
BS1- Sound deadener, Extra. *Note* There is a "deluxe" sound deadener package of BS2 for extra quiet. :)
B34- Floor mats, carpet, front
B35- Floor mats, carpet, rear
B85- Moldings, wide belt reveal, bright
B93- Moldings, door edge guard
B99- Wheel Well Molding- Delete (Included w/W42)
CC1-T-tops
CD4- Delay wipers
C49- Defogger, rear window
C60- Air Conditioning (required w/W42)
C87- Lamp, Rear Quarter Courtesy
D34- Mirror, Visor Vanity, Passenger
D35- Mirrors, dual sport, remote driver, manual passenger
D55- Console (standard on Salon)
D7I- Gear, speedo driven
D85- Stripe, special accent (Included w/W42) [not sure how this correlates with Y64, but it may be referring to the bumper stripes]
E5Z- Less speedo gear adapter
E7Z- Less speedo sleeve
F41 - Sport Suspension Pkg. (Included w/W42)
GMD- Stumped. I've seen these on GNs as well. It MAY be the rear end 8.5" housing? I don't know. Have yet to find a definitive answer on this.
GT4- 3.73 rear differential
G87- 8.5" ring gear
JM5- Disc/drum power brakes, dual diaphragm booster
K34- Electronic cruise control
K64- Generator, 78 Amp, included w/C60
LG8- 307cu. in. Hi Output V8 Engine, (Included w/W42)
MW9- TH200-4R (Included w/W42)
MX0- Marketing code for MW9
NA5- Emission system, Federal (non-California)
NP5- Sport steering wheel, leather wrapped (standard on Salon)
N10- Exhaust, Dual outlet (Included w/W42)
N33- Tilt steering wheel
N83- Wheels, Chrome 15x7 (Included w/W42)
QYH- 215/65R15 ROWL tires (Included w/W42)
TR9- Lamp Group, Convenience
TT5- Tungsten Halogen Headlamps, *Note* These were hi-beams only. (standard on Salon)
T83- Black inlay headlamp doors (Standard on Salon)
T88- Parking lamps front, amber (Standard on Salon)
UM6- AM/FM Stereo with Cassette
UQ1- Radio Provisions for Stereo
UT1- Tone generator, warning (Standard on Salon)
U21- Gages, instrument panel, (Standard on Salon)
U25- Lamp, Trunk
U26- Lamp, Underhood
U27- Glovebox lamp
U29- Footwell underdash courtesy lamps
U66- Speakers, extended range
U75- Antenna, Power
VD6- Bumper Support Front, Aluminum
VD7- Bumper Support Rear, Aluminum
VK3- Bracket, front license plate (standard w/W42) *Note* This code was not always listed but every VIN 9 car should have came with one.
VT5- Color Keyed Bumpers (Included w/W42)
V08- Cooling, Heavy Duty
V1P- Stumped. It is NOT "VIP". It's POSSIBLE it may have something to do with the body break paint lines being different than normal, but again, no verification on this.
V30- Bumper guards, F/R
V73- Statement of Vehicle Certification- U.S.
WL7- Popular Option Package Discount code *Note* Dealers HAD to put this RPO in if customer ordered the qualifying stuff, otherwise no discount.
W42- 442 package (Available on Salon only)
YT1- Deluxe Door Panel trim 442
YT9- Option package, Fisher supplied parts
Y64- 442 package ornamentation- Decals (Included w/W42)
Y78- Cutlass Salon- Changed VIN from GR47 to GK47.
12L- Lower body color- Metallic Silver
19U- Upper body color- Black
6NY- LH front spring code
7NY- RH front spring code
79C- Claret cloth interior seating and upper side panels
79I- Claret interior trim
799- Claret Seat belt webbing
8PZ- LH rear spring code
9PZ- RH rear spring code
It appears your car topped out in the high 15K range on the MSRP. I could probably even make a window sticker for it and price it out exactly. Sorry, this is the best I can do.
This is freakin awesome! Thanks a ton!
ck80
5,743
9,123
Kinda crazy to ask but any idea how I could go about getting a window sticker?
Depends if you just want a piece of paper that looks like one, or, if you want one that's as close to what gm made in the day as you're likely to get.
If the former, there's places online to Google. If the latter, 69hurstolds is your friend, schmooze him, beg, plead, and grovel.
Not really am exaggeration. Lots of guys use the same template for many years ignoring the nuances gm changed from year to year. He's a bit of a perfectionist with a body of Olds knowledge and resource accumulation that is pretty much second to none in my book
464ChillerTech
19
20
CC1-T-tops
CD4- Delay wipers
G87- 8.5" ring gear
U25- Lamp, Trunk
U27- Glovebox lamp
U75- Antenna, Power
That’s pretty cool. Would those codes be the same for an ‘83 Calais or Is there somewhere I can look mine up? mostly I’d like to know what the original interior/exterior colors were.
8,239
17,742
On your 83, you should have a body tag on the cowl underneath the driver wiper arm. It has some codes on it. While RPO codes remained pretty much the same year to year, (Ex: C60 was RPO for air conditioning on ALL G-bodies with manual A/C controls). There should be a two number code followed by an L for lower body and/or a U for upper body. If you have a vinyl top, you'd have a two number color code followed by a T. For example, 19L 19U and 11T. 19 would be black, and 11 would be white (IIRC). So your car would be black with a white vinyl top.
Take a readable picture of it and post it (start you a new thread please) and we can decode it for you.
Without the body tag, or other factory paperwork (for a fee, you can get an invoice copy with all the RPO options on YOUR car from GM Heritage Center, for instance), you'll have to inspect the car carefully to check for any color underneath the current color. Checking floorboard edges under the carpet for factory overspray, under the trunk seal lip area, etc. 84-up cars came with a SPID. 83 and earlier did not.
