I think the insignia may attract the wrong crowd..So you're saying I shouldn't paint it like the Hindenburg? 🤣
Looks great!Got off my a$$ and checked one project off the list today. Small retaining wall on the front corner of the house. Piece of slate you see is a step and will be the beginning of the sidewalk to the front door. Started at 9am, finished at 1pm. I'm whooped. It's 15 feet long and 2' tall on the right side.
View attachment 155728 View attachment 155729 View attachment 155730
Thank you! I've helped build them before, but have never done one myself. I guess time will tell how well I did it! HahahaLooks great!
The good news is they're like legos. Worst case scenario you take it apart in 5 years and rebuild it... and skip lifting weights a few days.Thank you! I've helped build them before, but have never done one myself. I guess time will tell how well I did it! Hahaha
Very true. No they aren't using the slab, they are just off of it on undisturbed ground so there shouldn't be any settling. I only dug down a blocks height. Used the landscape fabric, the runner crush, then stone dust, then the first course of block. Should be good. Famous last words LOLThe good news is they're like legos. Worst case scenario you take it apart in 5 years and rebuild it... and skip lifting weights a few days.
Nothing to worry about, and, looks good.
The only real question i have is based on what I see - it looks like the blocks are using the slab as foundation? If so, and, thinking of frost action, would that much weight (a few tons) on the edge promote slab tilt/heave? Would putting some type of cable lock footing under the edge to frost depth help support that weight help things?
If you think stacking the blocks is hard work, wait until you're shoveling load, after load, after load to backfill behind it lol.Very true. No they aren't using the slab, they are just off of it on undisturbed ground so there shouldn't be any settling. I only dug down a blocks height. Used the landscape fabric, the runner crush, then stone dust, then the first course of block. Should be good. Famous last words LOL
