I'll blast clean the holes with carb cleaner and then try loctite too. I only want to do this ONCE! I had a '75 Matadore wagon with the 258 motor, identical to the 4.0. Aside from the carb it was absolutely bullet proof. The Carter carb hopelessly sucked and I replaced the entire intake with a water heated one from some ancient junkyard Rambler that bolted right up. It came with a Holley 1920 carb about the size of a baseball. Once rebuilt it worted flawlessly. I also worked on a Nash, year unknown, with the same motor. Historic.
