It's a blast to drive. It's very quiet and smooth until you go wide open then it's a complete handful on the street even at 7psi.I'll bet that car is fun to drive!
Thank you. It took a good amount of time to make everything fit. The toughest part was being able to retain the A/C and route my exhaust the engine compartment. My goal was to make it look as factory as possibly without cutting the car up. The frame hasn't been boxed at this time. I did add the UMI rear shock brack which stiffened the chassis a lot and also prevented the car from twisting the chassis when I launch. The original F41 front swaybar is still in place too.That is a really well put together car. I like it when everything is fit into place so it looks like it was made for it. You don't mention anything about the frame but I assume you boxed it. Welcome to the forum.
It still has has the stock internals.very nice car. Does your L33 have forged internals?
What's the date and location?I'd love to ride in that thing. We have a G Body cruise coming up in September. Your not too far away from Okla.
Thank you. The A/C was a challenge. I used all Corvette accessories because they tuck closer to the motor which gave me about 1" extra clearance up front to route my 3.5" exhaust in between the water pump and fans.Clean install. Turbo with AC!....don't see many bothering to make that happen.
What motor mounts and transmission cross member did you use? What is your inclination angle?
