no start - help with diagnosis
DrRansom442
858
2
St Charles Missouri
OK, here's the skinny.
Fired my car up to go to work on Friday. I was bitter cold (maybe 18 degrees). She fired up and was running. She's had some cold weather issues, so I had her tach'd up to over 2000 rpm. I wouldn't use the word "stall" as she didn't falter, stumble or even hiccup. Was like I turned the key back "off" and she died. Well that is the last time I've managed to get it to fire up. Battery doesn't seem to be an issue as lights are all bright. Not the starter ... engine spins easily. No funny noises at the time it died and none now. The car has never once backfired. I assumed the coil or something distributor related must have failed. Since, I've owned it all I ahve done is replaced (ignitionwise) are the plugs. Decided a new coil, ignition module, cap and rotor may address the problem (certainly can not hurt right?). Well, I buttonned it all up and nothings changed. Gimmie some ideas. I can tell you everything that should be hot is, but I can not find my volt meter to tell ya it'sa full 12 volts.
dan2286
2,233
4
Cleveland, Ohio
A good place to start is to see if you have spark and fuel.
DrRansom442
858
2
St Charles Missouri
fuel no doubt - I've flooded her a few times. sorry. Lack of spark is where I am concentrating. Tommorrow Imma bite the bullet and pull the number 1 plug and see if it's firing and if it's blue. Rubber glove time!
dan2286
2,233
4
Cleveland, Ohio
They sell spark testers at auto parts stores. They can measure the intensity of the spark, and are much safer.
midwestls
1,497
13
Bismarck North Dakota
what motor/ignition system do you have? Is it stock yet?
DrRansom442
858
2
St Charles Missouri
car in signature. 81 Olds Calais, 260 cid ... engine is all stock
Sep 1, 2006
6,687
34
Tampa Bay Area
I would make sure you have 12 volts at the pink wire to the distributor before going any further. If not, it likely is the ignition switch. Sometimes they will just go like that with no warning.
DrRansom442
858
2
St Charles Missouri
good news is I now know the problem ...
bad news is it's going to be a big job (for the car to be sitting outside on gravel in the cold). maybe I can beg some friends with garages to let me tow it there.
I double checked the power to the distributor and it was fine ... so I pulled the cap off and turned the key ... rotor aint spinning. Damned timing chain must have come off completely. Why there was (or is) no racket is amazing and how it just failed with no warning is completely new to me, but the dist shaft is tight so it's not cam gear ... which leaves just one thing. Great just great.
dan2286
2,233
4
Cleveland, Ohio
That sucks. Just to make sure pull off a valve cover so you can verify the chain is broke.
Just to let you know, I had to re set the valve timing on mine on a gravel driveway and it wasnt that bad. Actually, all work I do on the car is on a gravel driveway since I cant move it because of no front suspension. I somehow managed to get my drivers side header in when it was 30 degrees outside 8).
