i just want to start by saying, i am grateful for the forum,i have found so many answers here,and u prob can not tell by the pics,but i have sorted out many problems already by reading and searching here. i bought this 1983 grand prix from (some one i thought was a friend),turns out this car is in far worse shape then i could of imagined.it has a aftermarket distributor and carb so from everything i read the ccc system/ecm is not in use.i went crazy with this rat nest of wires trying to figure out were things went.luckily using this fourm i was able to clean the rats nest under the dash and sort out what was needed and what wasnt. currently the rats nest under the hood needs to go,i have wires sittin on metal,grounded on the engine/bare wires ect.i went around with a test light and can not find a single of these wires with a 12 +.my project for today was to remove the ecm,because these aires arnt even connected to anything, pevious owner removed most of the emmisions,no cats no smog pump,and the emmissions related relays are ither unhooked or missing.i said all that to say this,after i remove this ecm,and get these wires taken care of what about my trans lockup. do i need to connect that,if so how, im guessing it probably is already unhooked,since the ecm harness is connected to pretty much nothing.any help is appreciated
