Ok I give, what's the trick to getting the shifter cable installed and then to work
Okay, just so you know I did UNHOOK the rod going up to the column lock out..............see PIC
and it made NO DIFFERENCE.................
I looked at the napa site, and the cable it brings up is for a floor shift at 29.3" long, but does not fit a hurst shifter. is it possible to measure yous and see if maybe yours might be the same as this one?
https://www.napaonline.com/en/p/BK_6202301
I've noticed a trend with all the suppliers, that they don't really give alot of info on what their parts actually fit... hope this helps.
Reactions: fleming442
This is the info I have off the internet as far as the length.............I need to remove the cable and measure it.
Brand: Pioneer
Part Number: CA-1150
Item Condition: New
Item Description: Auto Trans Shifter Cable
Manufacturer Brand Description: Auto Trans Shifter Cable
Quantity Needed: 1;
Fitment Notes: 28.78" Cable;
and the cable you referred to is
Contents (1) Cable Manufacturer Pioneer Automotive Manufacturer Part Number CA-1102 Transmission Cable Length 29.69 in.
UNSPSC 25173815
Thanks for the info
According to Rockauto (I searched interwebz using GM part number and landed on this- 79 Olds Cut Calais 5.7)
This is ALL the travel I can get from the cable.........the shift lever is in neutral. and will go no further
That is not the correct cable for that shifter. Just going by my memory the length should be 30. 5" or there about and the cables were the same in all other Olds Hurst years with dual gates even if it was a T350 OR T400.
Reactions: azmusclecar
Is this the voice of wisdom.........it would make so much sense. I will shop looking for that length and see what I can find.......thank you
Not 100% sure of that from my experience. The 70-72, 79, and 73-75 H/Os had different cables for different years. Recall the lower bracket for cable mounting for TH400 is slightly different than 350. I'm not sure if it's just the bolt mounts or the distance to the lever itself.
GM dualgate numbers were:
70-72 showed p/n 406266. 73-75 p/n 417536. Have no idea what the differences are, if any. It's weird because 70-75 showed the same part number for the dual gate shifter itself.
The bolt mounts are different, but the distance is the same. All of the dual gate shifters that I have seen and had looked the same to me. when I had my 79 TA I mounted a dual gate in it from an Olds with the original cable and it worked.
