Ok first offf whats up to every1 on here. Been away fixing up the regal and living life. So today I moved and was moving the car to the new house. It has been running decent until today when I started it it fired up and I let it idle for about 10 15 min. Then I drove it about a mile and when I started to go on a main street with a slight hill it bogged out on me. So I start it again and it fires right up but when I give it gas it will rev high as u want then immediately bog out like its getting no gas. So I replaced the sparkplugs again because as I mentioned before they are always oil fouled but I replaced them. Checked the fuel filter and its fine, still new. Replaced fuel pump which I must add was a serious b*tch and a half! Took me 3 hours on side of the road! Just for 2 bolts and a gasket to stay in place while installing. Anyway after the fuel pump installed I tried to start it and now it will just crank. I sprayed carb cleaner and it runs off of that then dies. I know im gettin gas because I can see when I loosen the connection that goes to the carb where the fuel filter is it spirts gas out. WTF my baby is sittin on the side of the road as we speak ready to be freakin stripped of parts and Im at my wits end. I only have 50 bucks on me till this thursday and that sucks cuz 50.00 wont help me with a tow. And in 4 days im sure someone will decide to mess with my car. What else should I do any1? I am really desperate this point and need every1s feedback. sh*t I just want to move my car to my new house and put it in the garage and start workin on it. Aghhhhhh!!!!!! :x Im venting sorry!!!!!
P.s. When I pulled the sparkplug wires off to change plugs, one of them popped off while the metal connection from inside got stuck on the tip of the sparkplug. I got it off and tried to recrimp it back on the wire and it let the car start up while force feeding the carb with starter fluid but it just will die out when hitting the throttle. Would faulty plug wires not allow the car to burn gas enough to stay at idle and actually run under load while accelerating? I dont get it the car ran idling for 15 min fine then drove decent for about a mile then just wants to not run period.
