- Feb 2, 2022
- 57
- 18
what type of cutter do you use? I don't want to hack anything up if i can avoid it.I just cut the nuts/bolts off the Olds mounts and spent my time bolting in the SBC frame mounts.
Angle air grinder with a cut off wheelwhat type of cutter do you use? I don't want to hack anything up if i can avoid it.
i have a belt setup from a circa 84ish block that i was planning on using. no A/C so no worries, I am going to keep the heat for now though.Look for anything A or B body up to 89 for AC, Alt, PS and etc. Pull everything up front. That will be your multi belt system, & AC on Drivers Side, use the AC lines from A Body Caprice or similar, PS will work better.
You can use front setup from 89 or after should be serpentine belt setup, but pulley from PS will hit or be too close to steering box. AC will be on Passenger side. You will have to keep air pump or serpentine setup won't work. There is no bypass pulley for air pump.
