X2.
There tons of stories out there about what has been done on a stock bottom end (SBE). IIRC someone has made 1400whp on a SBE 4.8, or something darn close to it with boost in the 50-60 psi range. The issue is how many SBE's did it take before they found the perfect tune and the perfectly balanced SBE? The sloppy 8f8 calamity is descriptive enough for those that followed it - and he's a decently practiced tuner.
I fully understand properly building a motor, and I understand the expense of that as well.
Hopefully Northernregals's build can get him to his goal without boosting it to the moon (mid 20's and above). It would seem that he should be able to hit 9's reasonably with 15-18psi on a 6.0 if his turbo and plumbing are up to the task.
I know I'm down with watchin 🙂 🙂 🙂
Stock GM LS Engine - Big Bang Theory - Hot Rod Magazine
Stock GM LS Engine - Take the Stock GM LS Engine. We are trying to learn everything about it's limits and we will tell you the results. - Hot Rod Magazinewww.hotrod.com
4.8 liter
1203hp, 26.8psi, 118 octane race gas.
93 is available, trustworthy is a different story.Speaking of Octane, is 93 available in Alberta? We basically only have 91 non ethanol readily available locally, maybe 93 in Regina.
E85 is supposed to be 105 octane but that really depends on the correct percentage that can be all over the map.What octane is E85? I assume the Holley system is compatible. How is the 93 not trustworthy?
I'm guessing 93 in his area is not high quality. Certain parts of North America have better blends than others. I'm lucky here as our 93 is supposed to be high quality.
