Ok, I will get an update today.Ahemm, your 4 days are up sir.
My thought is that I am probably only a little more front heavy than an iron head, iron intake SBC with all the factory trappings. The cage isn't really over the front and I've probably offset much of that weight with Door bar and interior removal. Moroso lists a 212lb/in, a 242lb/in and a 250lb/in spring set. The 212lb/in being for a V6, and I wouldn't be surprised if that's what was in the car.‘81Cutlass just installed a set of 5660’s. Would be great if he could get a weight distribution on the car.
Personally, it’s a total guess for a spring in a turbo’d car with a cage without some weights to compare. You’ve removed a crap ton of weight in the front, but then added darn near 100 lbs of boostey things. Does the cage cage add much onto the front end? I don’t know.
Do you access to a set of race scales?
