All I had to do was get the front down bars 3/4" farther rearward, but noooooo, had to be tight to the front.I see a shag carpet dash cover in your future.
Maybe some fuzzy dice to create the proper ambience
Maybe a custom built dash (sheet metal) would be a better route to go at this point? You definately have the talent to pull it off.
The intake doesn't help. -8 fuel x-over, 3/8 brake booster line and vac reference line, 2 injector harness connectors....All of my multiport harnesses are busy back there. I don't know a way around it unless you pull the wires from the top of the trans bell. But if you were to do that and you needed to access the wires, then it would require pulling the trans.
Ive been debating ditching my low ram base for a dual injector one.The intake doesn't help. -8 fuel x-over, 3/8 brake booster line and vac reference line, 2 injector harness connectors....
High ram would have been way better for cleanliness.
