I did not resize the rods, but yes, new (reman) crank, 1 new rod, rings, main and rod bearings. Same cam bearings.
I did put a new oil pump in the aluminum housing. It's basically LS style.
Oil pressure is still up around 45psi, but fell to 20ish at hot idle. That's really not bad at all, however, it started at 75/60.
Looks like it will be coming apart, AGAIN.....
