Operation Lipstick on a Pig
Does it shift through all the gears with out any bind or dident you make it that far yet
So, the answer to the $64,000 question is: sort of. It ends up being at the very end of the adjustment. Then, I broke the bolt off. So, while it was out, my Steam fitter neighbor was over, and just to give it more adjustment, we cut the rod and put a section of 3/8 schedule 80 pipe nipple in it. That lengthed the rod about 1/2", and now it works. So, in conclusion, if you have access to a 4 speed rod, use it, or you can modify a 3 speed.
Reactions: 1bad79
pics pics pics plz
pics pics pics plz
Nothing special
In other news: I got the through firewall wiring in, cut out the OBD 1 wires, started looming the new stuff in, so I can run the fuel pump, trunk release, and fuel sender to the back. Also, V2 of heaterbox repair......
