3 port fuel pump and 3 port sender. I'd be willing to bet that the line is there, and dear ol' dad just put a 2 port pump on. Blow it out to make sure it's clear.
There's an additional cause and effect here as well: get the engine to run cooler and the carb/fuel won't be as hot.
As said, your car should be a 3 line from the factory. The Olds RPM intake is 2" taller than stock intake or Performer. Actually most notch the RPM intake 1" down or so. Just more even distribution side to side. One side will always pull more fuel I ran a 1" open spacer and a 1" 4 hole spacer on the Performer intake. With it's small plenum, the 1" open spacer worked really well.
9265 or 9266Do you know the part number?
