liquidh8 said:Love the fuel pump and tank assembly. If I had to do mine over again (I may), that is a route I would go. Fabricating a bucket for the pumps, then using a universal sender in a separate hole.
Looks great, especially like the plastic clips holding the pumps.
PGLM said:liquidh8 said:Love the fuel pump and tank assembly. If I had to do mine over again (I may), that is a route I would go. Fabricating a bucket for the pumps, then using a universal sender in a separate hole.
Thanks, clips were very expensive, almost 1.5$/ piece...Found them from boat section, some sort of paddle holders... Clips are nylon, else is stainless steel, so they should last fine... 😀
liquidh8 said:Now you just have to fit it up, and get it balnced. 😀
