Posi?
Im assuming you mean bolts. I got a 10 bolt housing. Would that work or what would besides stuff from another g-body?
The 7.5 refers to the diameter in inches of the ring gear. That's how GM classifies their rears along with the number of bolts.
Posi continued
Thanks for the replies so far. I found a Richmond 8.5 10-bolt gears 3.73 on craigslist. Does anyone know if this would work for my app. I want a 3:73 or higher and think it would be better to change the gears rather than the rear. Let me know what you think.
An 8.5 ring gear will NOT fit in a 7.5 or 7 5/8 rearend housing.
Does anyone know the spline count for a G-body axle? Its stock with an open rear diff.
Would this work for me?
eaton 3 series posi rear end 3rd member with 373 ring and pinion gears 7.5 with 28 spline axels
How could I check?
If anyone knows. What am I ,ore than likely have?
I don't think it will because it is a 28 spline unit.
