Primer /paint question
Longroof79
Rocket Powered Basset Hound
Oct 14, 2008
12,319
10,178
Gainesville, Fl
I would like to start priming my car with urethane 2k primer. I plan on painting it a creamy white color. What color primer would be best, or does it really matter?
I was thinking either buff yellow or gray.
if you go to your paint supplier they should have a chart where they put the color your painting car over different tone of primer to see which primer is nullified by the color of the paint.
If it's your high build, color doesn't matter. Your sealer should be close to the final color.
Thanks guys! I appreciate your input.
Also, how do you rate Nason products? And is urethane primer neutral as far as using a different brand top coat? I noticed that some brands like Mar-Hyde, claim that you can use any companies top coat.
this is true. Most systems out there use a primer/ sealer /basecoat / clear coat system. Typically as black sheep said , the sealer color is close to the tint of the final paint, this allows fewer layers of base coat and helps even out the color. Sealers are for the most part monochromatic, ranging from white to black and the grey's in between. Sealers are kind of considered to be a primer, somewhat true, but it does not have filling/ high build characteristics.
I have not had experience with Nason, glasseret (idk the spelling it has a tropical parrot on the label), Tru-star ( a low end val-spar product), Dupont (single and bc/cc systems), a German based paint named bear or debear (idk its been 5 or 6 years since i used it). All are pretty decent quality, you don't HAVE to use a high end paint, it will show in the final product undoubtedly. However you can use a lower grade paint and you will be fine as long as the prep work is spot on. My cutty is painted with a tri stage dupont system ( sealer / base coat/ pearl coat / clear coat. I painted it back in 2003 and still today the paint is holding up very well and is not peeling or cracking. I've used Marhye products, mainly the rust converter that they produce. It is a decent product and does the job well if your patient. As many other members will say, use POR-15. The stuff is really expensive but works, just don't get it on your skin as you will have a spot there for weeks.
Check with your local paint supplier for the compatibility of primers and paint systems. Most claim they are universal, say a urethane system should stay all urethane, don't mix a lacquer type with it. Even so some paints will not be compatible within a urethane system, they can cause all sorts of chemical side reactions that will cause lift off , fish-eyes and other imperfections. Trust me the easiest thing is to go with one paint system, you wont run into all sorts of headaches. But again check with the paint guy.
I do have to mention this about re-spraying our old cars. The paint they used was typically lacquer based paint, you ended up with a lot of checkering or crow's feet with these paints. Make sure you use a nice high build primer to minimize this showing through. one of two routes you can go is completely stripping down the paint to the metal and working from there, this is the best and "proper way" to re-finish the car. The other route is just prepping the current paint surface ( a lot of sanding and scuffing) and applying good even coats of primer, sand it down and see if you have any imperfections, then repeat with 2 coats of primer. The rule of thumb with newer cars is to paint over the OEM finish, the newer cars go through paint /baking processes that make the paint stick very well to the body, so this is a good base to start off painting over as long as the prep work is good.
good luck!
I stick with the same brands so I know everything is compatible..I don't like surprises and I hate when the guy at a paint store says 'really?...that never happened before"...
Thanks for your good advice and input gp02.
I was also wondering. I don't plan to shoot the topcoat on the car for at least several months. Would it be a problem with the urethane primer if I didn't topcoat right away...or within 24 hrs?
Yeah, I guess I'll stick to one system. Less surprises that way.
usually its not a problem. stuff like body filler and primer are porous to an extent and should have a coating on top of it if its being exposed to harsh conditions ( much like every day driving)
you can shoot the primer on there now, and you can get it to lay pretty flat if you know what your doing. I can spray primer to have less peel than clear coat with my 2.0 needle iwata.
you can spray the primer , but don't t let the car sit out in the rain or anything, contamination issues and will end up with some surprises. Over a long time like that i would not use any type of tire treatment as well, like tire shine. Things like tire shine that have silicone in it and other waxes in it will leach into the paint/primer. This makes applying another coat very difficult.
I would suggest holding off on the primer at least until you within 2-3 months or sooner to apply base coat and clear coat. If you cannot do that and you have to spray primer soon and wait 6 months to top coat it, i would only spray the primer and wait until your almost ready to paint to sand the primer down.
Thanks again for your advice. It's much appreciated. The problem is, the car will be outside for awhile. It won't be subjected to snow and ice, but rain.
I suppose I can put a tarp or cover on it when I know it will rain, and remove it on dry days. Again I'm open to advice. My garage is full, so it won't be living indoors for awhile.
What's a good size tip to use on my spraygun? My cheap primer gun has a 2.0 tip. I've used it to spray polyester primer...but would probably need something smaller for the urethane...like a 1.7? I think my other cap and tip are 1.4. I'll have to check.
