No spacers at all. I think what you're seeing is the center of the rotojoint, which has a built in offset to the portion that the bolt goes thru..I'm sorry I am rambling here. I have rotos only at the front with poly rear. It seems like you have one spacer on outside of each?
Wouldn't it be better to have smaller spacers on each side? Which is what I believe I have at the front end of uppers.
So the only thing I can think of that would have caused over articulation is when I installed the rearend after it was rebuilt. If I had installed the upper arms first, then the lowers, maybe the rearend pivoted downwards too far and damaged the joints before the rear was fully installed... I can't remember what order I did it in, but I suppose it's a possibility :/
