BUILD THREAD Project long time coming
Yes, I was thinking about it, but didn't think I could slip the whole drivetrain in at one time. Another tough lesson to learn. Even if I couldn't put it in all together, I should've tried it together out of the car first.
Bummer on the pilot bearing.
Just don't use the bread (or grease) in the cavity with a punch trick because LS stuff has a plug in the crank and it will fill the crank oiling passages instead of removing the bearing.
Yeah, I read up on that when I was trying to see how to get the pilot bearing out, but thank you for the heads up.
Reactions: Tony1968
Well, looks like I have a chance to get in the garage tonight to yank the trans back out. Finally. The parts fairy showed up too.
4" diameter tubing, elbow, K&N filter, and clamps. Excited to see how it all turns out.
Please do. I have a slight leak. It's either that or main seal.
I would say more likely main seal. Check out the pic on my 170k mile 5.3 in my truck in post #1. I replaced the seal and leak fixed.
