BUILD THREAD Project long time coming
Streetbu
Know it all, that doesn't
3,740
11,592
Central NY
Yes, I was thinking about it, but didn't think I could slip the whole drivetrain in at one time. Another tough lesson to learn. Even if I couldn't put it in all together, I should've tried it together out of the car first.
81cutlass
4,649
13,565
Western MN
Bummer on the pilot bearing.
Just don't use the bread (or grease) in the cavity with a punch trick because LS stuff has a plug in the crank and it will fill the crank oiling passages instead of removing the bearing.
  • Wow
Streetbu
3,740
11,592
Central NY
Yeah, I read up on that when I was trying to see how to get the pilot bearing out, but thank you for the heads up.
DRIVEN
8,078
14,551
*CENSORED*
I used a body saw and made mine a 2 piece after the other methods failed me.
  • Wow
Streetbu
3,740
11,592
Central NY
Well, looks like I have a chance to get in the garage tonight to yank the trans back out. Finally. The parts fairy showed up too.
4" diameter tubing, elbow, K&N filter, and clamps. Excited to see how it all turns out.
Streetbu
3,740
11,592
Central NY
Success. Trans is back out, safely without hurting myself. I'll borrow the pilot bearing tool on my way home tomorrow and get the incorrect one removed.
Reactions: 7 users
Streetbu
3,740
11,592
Central NY
Great job 👏
Is it true that there is a Plug in end of the crankshaft?
So I've been told, I'll snap a pic tomorrow when I get the bearing out.
7,989
18,702
Please do. I have a slight leak. It's either that or main seal.
I would say more likely main seal. Check out the pic on my 170k mile 5.3 in my truck in post #1. I replaced the seal and leak fixed.
