Update from the weekend.
After being tied up with commitments all day Saturday, and the weather finally favourable after the Snowpocalypse the previous week, I was under the gun to get the edges of the hood in paint. It might’ve been my last chance for the year.
So knowing I had a ton of work to get done, I was up and in the shop before dawn while most folks were still pounding their ear. I did a shop cleanup and put everything that wasn’t needed away. Then got down to hanging and prepping parts until it got late enough to fire up the car and pull it outside.
Hung the mirror halves with a little creativity...
...with the thought that I’d be able to prime and paint both halves easily this way. This was only mildly successful and had a major flaw in the plan, but I’ll get to that later.
While I had already stripped the 3 accessible sides of the hood and bodyworked and primed the topside, I obviously wasn’t able to do anything with the rear edge while it was on the car.
With it set up upside down on the stand, I was finally able to see what I had to work with.
The folded over flanged section got carefully stripped down to bare metal with the Clean n Strip wheel on the die grinder from edge to edge:
Then my favourite, (insert sarcasm here) more masking:
The underside had already been scuffed and shot with VHT satin black a couple years ago to cover up the overspray from the shitty previous paint job, and I didn’t want the entire underside body color, so it got masked off as well. (Bruce 😉)
That took care of the prep on the hood, but in the time since I stripped the mirror and signal indicator, the pot metal had lightly oxidized (it happens pretty quick when it’s unprotected), so both those components got a thorough scuff with red ScotchBrite and a good cleaning.
Time to play amateur chemist. A batch of epoxy was mixed up and the first coat shot on all the parts. The fender mounted signal indicator is visible near the center of the hood:
Here’s where things got a little tricky with the mirror. I shot only one coat of epoxy on both halves of the mirror parts where they join for corrosion protection...
...then assembled the halves because I knew I had to have something to hang onto (the protruding studs) if I was gonna have a chance of getting any coverage inside the housing around the glass.
After it was reassembled, it got 3 full wet coats like everything else.
After the required hour from the last coat, it was time for color. 3 more wet coats of color got nice coverage on (almost) everything. (More on that in a bit)
I allowed everything to dry as long as I could, then returned to unwrap my “Christmas” presents. They all turned out nicely. Lots of pics here guys, but I was trying to get all sides and angles for y’all to see.
But now I had a conundrum. I had an unmasked not dry yet large panel in the middle of the garage, the car outside, and no way to pick up the hood by myself without touching any of the edges.
Thankfully my neighbor was home and I was able to enlist his help in getting it moved off the stand. After “borrowing” some pool noodles from his son, he and I were able to set it up on the hood of The Juggernaut temporarily.
Not what I would’ve preferred, but sometimes beggars can’t be choosers:
Continued >>>
