I questioned (in my head) the location of where you placed the 'notch' height wise then thought it probably didn't matter.
When I did mine, I tacked some fasteners to the fab table so the x-member could be bolted down square to the fab table (like it would to the chassis). Once bolted solid, I positioned where I needed/wanted the notch, marked the area for removal, tacked a couple tabs in place, & cut the section out entirely. Each side was then welded to the notch/channel piece which left the top slightly higher vs the original x-member but still w/the thickness off my fingers away from the floor pan. Your mod is far cleaner appearing vs what mine was once completed as far as a proper 'nothing to see here folks' appearance.
Thank you, I appreciate the compliment.
How you did yours is exactly how I would do it if I had to do it over again. There’s some room between the bottom of the floor and the top of the crossmember, so it’s definitely do-able. I thought I was going to end up with a lot less clearance to the top of the notch than I did, so I’m still quite happy with the end result.
'yarding' the 8.5 ? Help this Yankee understand that term 😉
You could've put a dimple in the left side pipe to help with the ground clearance. But I believe it's one of those things that you're the only that will ever notice - no one is going to 'cut you up' over the left side pipe road clearance lol.
Better than nice work as always D.![]()
yard noun (1)
\ ˈyärd \
Definition of yard
1a : To yank, pull, tear out, or otherwise unceremoniously remove: “Cleetus, grab dat der 9/16’s, we’s gonna be yarding dat der turrbo outta yonder dump truk!”
b : Yarding, the act in-thereof of participating in the aforementioned action.
I kid, I kid.
There’s zero issue with ground clearance. The clearance I was talking about was between the top of the pipe and the homemade notch.
