Thanks for the replies gents. I was out for a bit so I missed them all.
So here goes...
Yes, that’s where the tach is currently attached, and that’s where I tee’d the grey wire into. (I’ve since removed the grey wire from being tee’d in as I want the tach, and for the car not to die suddenly while I’m driving if it accidentally grounds out.)
The tach wire is the brown connector on the LH side of the distributor cap:
Gotcha. Thanks for the info. I agree, that’s not a very good rating for their product, but I always take those reviews with a grain of salt because you never know if they were installed correctly. I’m willing to bet 80% of customers problems with (any) products are probably due to improper installation.
Not likely Steve. I’m sure theirs is a quality product, but due to the fact they aren’t available to me locally precludes me getting one anytime soon. Not to piss and moan about it, but we Canadians get ripped off enough on the price of commodities up here, I’ll be dammed if I’m gonna fork out an additional 35% more with the exchange rate to get something brought up from across the border. So unfortunately for me, I’m stuck with what I can get locally, or at least on this side of the border.
No dice. As I said earlier, the wiring on this car is all original and not hacked. The following picture is the tach wire (brown connector) directly from the distributor cap to the firewall grommet. All I did was loom the wire to make it look cleaner.
Pulling the grommet out and some of the slack in the tach wire from inside the car reveals no filter either. I can strip the loom off and show you the untampered-with wire if you’d like...
No apologies needed Jared. I did post the cam specs much earlier in this thread and more recently in the QuadraJet thread, but I don’t expect you to go digging through all those pages to find it.
Here they are again:
The power brakes have zero issues whatsoever. I actually had to make a couple of rapid stops during my cruise tonight, and was pretty impressed with just how well the brakes work on the car. Certainly no problems whatsoever with a lack of vacuum for them or anything like that.
The booster and the master cylinder both are fairly new, maybe a year on them since I replaced them last year, so I can’t see how they would be a consideration in the equation?
More than likely, I was probably using a fitting on the carb that was ported vacuum rather than absolute manifold vacuum. I’m not sure if that would have a negative effect on my readings or not. I’m gonna try tuning with the vacuum gauge on true manifold vacuum here in another day or so.
I’ve actually got a spare MSD 6AL leftover from The Juggernaut that’s still good, but I’m pretty opposed to installing it in this car especially if just the module will do the trick. I’m trying to keep things stock appearing under the hood, so for me mounting a big red brick to the wheel well or firewall is a big no go. Not much room inside the car for it either, so I’m trying to avoid it altogether.
Thanks for the heads up on the secondary air door tip, I haven’t got that far in Cliff’s book just yet so I’ll look into it. And I believe you’ve hit the nail right on the head, it feels a bit sluggish when the secondaries open, I’m betting it wants more fuel. Gotta wait until the special order parts show up to rectify that tho.
So here goes...
I thought all the G bodies had the filter on the firewall, anyway I just looked at the instructions again and have you tried plugging the tach in the normal regular connection on the cap?
It has 47 reviews just on Summits site and 15 of them are poor (3stars and down)
To me that not good for the so called "leader" in automotive electronics.
The Davis module has 28 reviews all 5 star.
I'm hoping that Donovan will be the 48th review giving it 5 stars
They all are mounted on the firewall (I'll exclude '86-'87 GN & the GNX since I know nothing on their set up.) Buy chance an earlier owner cut it off thinking there was an issue?
Donovan,
12" of vacuum seems pretty low. What are the cam specs? Did you post them already? If so, I apologize for the question. How do the power brakes feel? For grins, you might disconnect and plug the hose to the booster and see if you get a better reading on the vacuum gauge.
Sucks to hear about the new MSD HEI module. I really like the Ignitor 3 module, a rev limiter and almost multi spark. I have blown 2 of them, one was my fault. The other, I had an issue with the power wire, not putting out enough voltage and it died. I have it in my 88 Cutlass, right now. I would check how far the secondary air door is opening, betting it is serverly limited. Cliff's book shows how to measure and it has different recipes for different motors. Also probably your extremely lean secondary rods are limiting it. I can feel my secondaries open and feel the rush on my 70S.
