jlcustomz said:Thanks for the measurements, Waiting to see what you use on rear.I have plate steel for bag brackets, just need to find a little 5" od pipe.I'll probably just use manual pneumatic valves for price [airlift] ,simplicity &less maintenance in a damp envirinment. Thinking slam specialties bags in front RE-5 or RE_6 maybe even ss series. Not sure if slams or firestone tapers on rear. May do engine driven compressor. Right now I,m just collecting more knowledge, I le the outcome of my projects to be like I,ve done them before.
Knew about the early model year difference on spindles, Had you known earlier, you,d still be doing the same thing in the long run. may as well shake it off & call it the joys of hot rodding. Keep at it ,---- when work & life permits.![]()
boatshoes said:Finally can see what I'm working with. The front fender is stopping the wheel right now, the bag still has a few inches left to go. Some different wheels would fix this too, but I really want to run these so I will cut the fenders up. Quick phone teaser pic.
