4
2
7
S
B
O
Mine will be 424.
"It's just a cruiser"Yes, but now I may just go with the full girdle setup with the pan rails and modified oil pan.
MUHAHAHAHAHAHAHAHAHAHAHAHAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
The 455 builds seem to fail fairly often, especially under power. I say it is 3" main bearings and a very heavy rotating assembly plus big torque numbers. These 4" stroker crank builds start at 400+ hp and 500+ ft/lbs on mild iron head builds.That will be totally cool. I just don't understand it myself when a minimum of 455 is available. If stroking is the desire, then how much is too much? Unless something about the setup allows it to rev past 7000 or the setup is significantly stronger allowing BOOST or Nitrous in large amounts.
Although hiding 424 inches in a SBO package is very deceptive (aka 'a good thing')
If it just about being different, then that is the best excuse that can be used. I am very good with different. VERY good.
Bet that b*tch runs like a raped ape, though!!!!!!His response was you should just buy my SBO 370..............
I imagine Bill is doing less Olds all the time. With the new Rocket Racing block, probably just not necessary for girdles for anyone building anything serious. I would say your 403 with any cam will be 325hp and 400 ft/lbs. Is that second number torque? They put out 320 ft/lbs bone stock. That is a peanut cam, 7.8 to 1 if lucky and awful exhaust.PTR called me back this morning
He said he is out of the girdle and isnt making them anymore.
I asked him if he thought it was necessary on a 325/300 403.
Now thats great service!!![]()
