What fuel pump is on the engine? Quadrajets don't like more than about 3psi of fuel pressure, from what I've read.
15/32 as per the manual that came with the kit. I get all my stuff from quadrajetparts.com, never had a problem. I've checked the air horn and the main body, top and bottom, and the throttle plate for warpage with a machinist's straight edge, and it is not warped. I put the air horn on the main body, sans screws, and there was no rocking movement at all. It sat flush. It was really cruddy on the inside, it sat for a few years is my understanding, but I didn't see or notice any hairline cracks or anything. I filled the bowl with gas and let the main body sit overnight on a piece of paper with ink on it, and the paper was dry as a bone and the ink was not smudged one bit. But it's still leaking somewhere. I did use an oddly thick base gasket, but when I used the thin one that one was wet as well.if you have built 20 quadrajets we should be asking you questions. What is the float set at?
It's just a stock, or stock replacement fuel pump. The engine I'm testing it on came with a qjet from the factory and currentlly runs just fine with it. But when I swap mine on it sounds like crap. Is it because my qjet is for a 350, and I'm testing it on a 305? It's the only working SBC I can get my hands on for testing purposes.What fuel pump is on the engine? Quadrajets don't like more than about 3psi of fuel pressure, from what I've read.
No leaking at all, until it is put on the engine. I did not epoxy the plugs, I just replaced them. I bought some of that marine tex... whatever epoxy and slathered it on the new secondary plugs and primary plugs. I'll test it later today (monday) and see if that made a difference. I also got a thicker air horn gasket in it.it is leaking when you filled it and it is just sitting one a bench ?
