Just the way the intake layout is. Buick intakes are lower and wider, and the damn water neck isn't right in front of the carb on the intake, it's on the front face of the intake above the timing cover. Plus the SBC im working with has all the emissions BS on it plus AC, so I can't remove any of it to get to anything. I can still reach them, but it's made so much more difficult. I hardly ever work on SBC, idk why but that's how it's worked out so far. On BOP motors, stuff is just spaced out better. Even on my 429 ford I had, everything was reachable without removing anything on the top end of the motor.What can't you get to that you can on a Buick?
Steve- in my entire life I have never seen a Q-jet bowl leak from a crack or casting imperfection. It was always the well seals and after the Rochester factory upgraded the pressed-in plugs that never happened again. It has to be either the float or needle.
