Building a qjet for a guy, and it idles VERY high, at like 3.000 rpm. I managed to coax it down to 1400, but it refuses to go down anymore. Also, the base gasket that sits on the intake is wet every time I remove the carb. I have replaced the secondary plugs with the o ring plugs that quadrajetparts.com sells. They do not leak, nor do any of the other plugs that I can see. It also seeps fuel in between the main body and top surface of the throttle plate gasket and somewhere underneath enough to wet the base gasket. What is going on here? Is this carb just junk? It's a 17057204 off of a 78 corvette with a stock 350. And to be fair, the engine I'm testing it on is an 81 305, but it's all I got to work with. I've built maybe 20 qjets so far, and I've never had one as troublesome as this one. Any help is appreciated.
