It's also going on a 99% stock '78 corvette, which according to the specs for the carb, had an astronomically high high idle of 1600rpm, so I'd say I got it dialed in as much as I could.
I listed what all the columns were. And I've said it initially was 1400rpm cold idle and it wouldn't idle down. Fixed that, now the high idle is properly set at 1400 (I thought 1600 was a tad high, but that's just me), and it idles in park at 900-1000 when warm. That was on a 305 though, not the 350 the carb was meant for. The gasket that I used was the really thick open gasket that doesn't have the holes in the middle for each blade, just a big open hole. I could've turned it down more, but it was futile to do so as his engine is different than mine. I solved the fuel seeping issue and the sticking fast idle, that's all I needed to do. It's his job to set it and tune it right to his engine. I got it to idle in park at 1000 rpm, that doesn't mean that's as low as it will go.you are missing the top of the chart that tells you what the column is....that 1600 is for a cold rpm, not an idle in park after it's hit operating temperature...and just because that is the spec if you can't turn it down then there is something wrong with the carb.
II had it as low as 900 warm in park, and it ran it's best on the 305 that way. But again, what the owner of the carb must to do make it run right on his 350, is different than the settings I had to make it run well on the 305. I set it where I know it would run decent as soon as he got it. It's his job to figure it out and tune it precisely to his and his engine's liking.how low can you adjust the warn idle?
