Question on 1990 5.0 IROC TPI swap
Cuse99
251
126
I got a line on a '90 5.0 TPI from an IROC. Comes with the 700R4 trans. Looks likes its mostly all there from the photos. It has the wiring harness but I can see there is an empty brake on the both sides. Probably a pump of some kind. Claims to have 48K miles on it. For my plans on my Elco this might be just the ticket. But I'm curious of what to look out for and gotchas on a swap for this.
Disregarding the trans for the moment because I know I'll need a new cross member and driveshaft etc...
  • What do I need to look out for in the motor?
  • Are there parts that are really expensive or hard to find that I should make sure are included? Like the CPU?
  • Will this unit otherwise drop it?
  • How about the wiring?
If this isn't too complex I'll pursue it. I remember these motors made really good low end torque and decent power. More than enough for a street car daily driver.
I appreciate the comments in advance, thank you.
ck80
Moderator
Moderator
5,743
9,122
TPI setups are a minor pain to swap and arent easily nodded for further horsepower.
From a cost effective basis I'd hold out for a truck motor.
Cuse99
251
126
I'm not looking for more power, 275 HP is fine for me. What is cost effective about a truck motor? I'm not following?
motorheadmike
8,976
27,522
Saskatchewan, Truckistan
64nailhead
Goat Herder
Dec 1, 2014
5,710
12,219
Upstate NY
TPI is as easy as any other motor of that era. If you can afford it, then go with an aftermarket ECU, you need a fuel pump and lines. You'll need to modify the rear crossmember for the 700.
ck80
Moderator
Moderator
5,743
9,122
Search L31 or LO5 350 v8 truck builds.
They have roller lifters so no zddp or wiped cam worries, but can run off the original technology in your car.
You don't need to mess around with wiring conversions - they don't need a computer, but, if you REALLY wanted to you could use the stock one and setup.
No need to worry about out of production MAF and other sensors that drive you into cheapo Chinese or junk remanufactured as they fail.
Because they aren't fuel injected, you don't need a new gas tank, new sending unit, new larger diameter fuel lines, or to buy and wire in an electronic fuel pump.
A used motor will only cost you around 300-500 bucks complete top to bottom front to back with around 100k or less on it, leave lots of money to buy cam, heads, intake, and carb to really wake it up to the around 400hp range.
64nailhead
Goat Herder
Dec 1, 2014
5,710
12,219
Upstate NY
Dude, that’s a lot of hatin’ on the fuel injection.
Did your ex-wife used to prefer it or what?
Kidding of course. OP - I wouldn’t try it with a stock pcm. And beware that you’ll have $1500 in getting a TPI to go. I can break down the cost if you want. CK80 is correct that a carb setup L31 or L05 will be cheaper (but it won’t be anywhere as 😎)
64nailhead
Goat Herder
Dec 1, 2014
5,710
12,219
Upstate NY
Nothin’ cooler than a TPI - not the fastest, but definitely cool (to me anyway)
Reactions: 8 users
Clone TIE Pilot
3,859
2,611
Galaxy far far away
Both TPI and L31 will likely require a electric fuel pump conversion. In tank pumps are generally the best. TPI was a popular old swap for G bodies years ago.
Texas82GP
Just-a-worm
Apr 3, 2015
7,989
18,697
Spring, Texas
With all due respect, where are these 20+ year old, less than 100k mile truck engines, for cheap?
