- May 9, 2022
- 123
- 18
Finally received my QP rear end and installed the housing for the most part. but i did realize the rear bottom bracket does not fit correctly at all. even if i bolt up one side and leave the other to drill it open there will be a large gap. i cant be the only one with this issue. was a real pita to get the bottom trailing arm bolt in just to find out that i needed to use a longer bolt equipped with the coilover bracket but that was my fault. Going to call quick performance in the am and if not ill call aldan american to see if they have an option.
