Rear differential cover torque spec
Rocket350olds
Jun 6, 2020
91
48
I have a 86 cutlass supreme with a 7.5inch posi out of a monte carlo I'm using a chrome diff cover and the lower bolts came loose and the oil drained out anyone know the torque spec?
pontiacgp
blank
Mar 31, 2006
29,270
20,391
Kitchener, Ontario
I make them tight and use locktite on the bolts but if you plan to get the torque wrench out...if you use a gasket make sure you do not crush it
64nailhead
Goat Herder
Dec 1, 2014
5,710
12,219
Upstate NY
15-20 is fine, but I would clean off the never sieze and put either blue loctite or silicone on them.
