Yeah, but you're from Texas where they are known to be risk takers and law breakers -at least I seen that in a movie (so it must be true!! 🙂 )
What are you running for a converter? The OP's converter should put him well past the rpm that your motor will produce more torque than his? Meaning that your motor will out grunt his at 2500, but with his converter it should jump to 4K pretty quick and never really pull much of anywhere below 3500. But I do agree that he will be turning tires to smoke at 4K rpm's from a 2500 WOT stab. Mine takes about 3/4 to a full second, but as mentioned previously, he has a smaller turbo that should light off quicker.
Why not reuse the TrueTrac? Or do you want to run a spool? If you want a spool, then remember that they are not street friendly.
