Trying to figure out what gears I have in my 78 cutlass. I found these #'s on the rear diff 2RA 0 527. Can someone help me out. thanks.
SLICK79WGN said:you need the codes off of the axle tube on the pass side it will be on the front side facing the transmission
n33no said:SLICK79WGN said:you need the codes off of the axle tube on the pass side it will be on the front side facing the transmission
those are the #'s from the axle tube. is there a site i can go to for this info?
