Rears school me please
Clutch
5,190
10,923
Brick NJ
Without getting into the good rears I want to know more about the stock g-body rears and what else used 26 spline Axel's my 78 Cutlass has a stock rear with 2.56 gears I have a posi unit in my shed with 4.10 gears out of an S-10 will it work with like 3.23s I know it's a stage3 so that's the tallest it will take ideally I would like to have a 3.08 posi but I'm not trying to spend the cash right now. So that said clue me in guys I'm a bit confused and what's up with 2 different sizes toothpicks in these cars 7.5 and ??7.62??I'm lost and can't afford a 9" what's up?
lilbowtie
3,460
3,965
Canton Mi
83 through 92 S-10 used 7.5 gears w/ 26 spline axles - 28 spline axles were available 88 up
  • Informative
pontiacgp
blank
Mar 31, 2006
29,270
20,419
Kitchener, Ontario
Yes now I just need to count the splines because I don't remember what year the s-10 was it was a square one but a 4 door
if you have to start looking for 28 spline axles and have to install that carrier in your rear end with a new crush sleeve if I were you I'd keep what you have till you have the money for the rear that you really want.
TURNA
Rocket Powered Basset Hound
Jul 24, 2009
10,941
19,996
Socialist NY
This is a good rear to have.
I suggest you start looking for one ASAP!!
https://bootyoftheday.co/wp-content/uploads/2013/04/cute-rebooks-big-*ss-in-yoga-pants.jpg
  • Winner
Reactions: 10 users
Oct 14, 2008
8,846
7,819
Melville,Saskatchewan
88 and up is supposed to be the change over to 28 spline axles, they may be exceptions so count the spline. As said factory replacement 3.23 gears are tallest gears that will fit that carrier, not the end of world with a taller tire. You can get thicker gears to run higher ratios on your 2 series carrier but there isn't gears to go the of other way. That S10 posi is a gov lock or gov bomb as most call them. Unless you are going to the track, a 3.08 open isn't the end of the world, although I would upgrade to aftermarket spider gears, myself and other have had them explode.
  • Informative
StreetStock#72
136
165
Might need a 8.5" to fit that center section.
TURNA
Jul 24, 2009
10,941
19,996
Socialist NY
Just get a running start you'll do fine!!
